broadcast transmission
Dear All
I have a PTP link between two ePMP (bridge mode, no nat enabled, no firewall enabled)
the scenario is:
DHCP server-LAN ePMP AP ==link === ePMP STA- DHCP Client
in this case all works fine, DHCP client obtains IP from dhcp server
2nd scenario :
DHCP server-LAN ePMP STA ==link === ePMP AP- DHCP Client
in this case DHCP client does not obtain any IP from server.
I need a transparent link between the endpoinds, how can I solve?
Thanks a lot
Regards
The second scenario in your example above is not supported. The device connected to the DHCP server must be configured as an AP.
Dear Sir
so it is not a full transparent bridge correct? I mean I cannot use server services in the network segment managed by STA, correct? Do you know if this mechanism will change in the next firmware update?
Thanks a lot
Regards
I have notified our developers and work is underway to accommodate this scenario. I doubt this will be in the very next release but I will try and push this up the priority queue with the development team. Thanks for your feedback and patience.
I have the same kind of problem, novelty?
Set "DHCP Server Below SM" to Enabled under Configuration-->Network.
