cnMAESTRO password - .1.3.6.1.4.1.17713.21.3.20.4.0
wirelessRadiusUsername - .1.3.6.1.4.1.17713.21.3.8.5.8
wirelessRadiusPassword - .1.3.6.1.4.1.17713.21.3.8.5.9
.... and many, many others. What can I do?
firmware 4.4-RC30
firmware 4.4-RC30
Thank you for your feedback.
We will check and revert to you shortly.
Thank you.
firmware 4.4-RC30
These 2 work well for us:
And we are fixing this one:
Thank you.
If you're using the read-Only community, try the Read-Write and see if they show up. Some stuff was removed from Read-only at some point.
Mathew is right.
For security reasons, some OIDs like passwords, logins, radius settings are hidden for the public community.
You can read it only using private community string. Here is the list of such OIDs:
snmpReadWriteCommunity wirelessRadiusIdentityRealm wirelessRadiusUsername wirelessRadiusPassword wirelessRadiusIdentityStr wirelessInterfaceEncryptionKey wirelessRadiusTimeout wirelessRadiusRetry wirelessRadiusGUIUserAuth wirelessRadiusUseDefaultCertificate wirelessRadiusCurrentGUIUserAuth useMACAddressAsWirelessRadiusUsername wirelessRadiusUsePMP320Certificate wirelessRadiusUsePMP450Certificate wirelessRadiusPMP450Certificate wirelessRadiusDefaultCertificate wirelessRadiusPMP320Certificate networkWanPPPoEUsername networkWanPPPoEPassword wirelessRadiusSeverInfo wirelessRadiusUser1Certificate wirelessRadiusUser2Certificate CambiumJSONCfgExportLink
