Bulk setting channels on cnPilot via cnMaestro
Is there a method in cnMaestro to bulk configure the channels used per radio across a large number of APs. In XMS-E there is the facility to export the radio settings to excel, modify and import.
At this time there is not a method to bulk import radio channels.  The API does allow for setting channels used per radio for individual devices.
hi,
one option can be do it from site using configuration override. it still do changes on each device at a time and push the cnfg in one shot. you can see attached screen shot for the same
