Could you please tell me if I need an special cable for the connection between the switch cnMatrix TX 2012R-P and cnPulse GPS?
Is enough to use an 8-pin shielded straight through CAT5 cable?
Thanks in advanced
Thanks in advanced
A shielded CAT5 cable is all you need. Be sure to plug the cable into the AUX port of the cnPulse and configure the switch to provide power to the cnPulse.
Thanks for your advise Vern
Ever had the cambium sync status go to “not in sync” on its own? Mine is and the only fix is to power off then power on the cnPulse power state.
