This has been tossed around a bit already, but has anyone got the Signal to graph in Cacti for the OFDM radios?
I’ve got all set up in Cacti but it just won’t graph. Been hammering away at it off an on for almost 2 years now and it’s almost to the point where I’m goinna have to tell it to go to HE-Double hockey sticks!!
To let everyone know I now have the power level graphing for Moto’s PTP400. I’m alittle in shock that it’s working.
Because the radio reads the signal as a 10th of a db the value is 10 times what shows up in the GUI.
For example. If your Signal is -69 in the radio it will be -690 in your graph.
Anyone that is interested can PM me for help.
You will need to configure a CDEF that divides the number by 10 on the graph template.
Frothingdog.ca wrote: Because the radio reads the signal as a 10th of a db the value is 10 times what shows up in the GUI.
If anybody else is interested in graphing signal levels for the PTP family then you can try using the following graph template. Sorry if this breaks tables.
<cacti>
<hash_00001304757f1c388446f9aebf3322068600e7>
<name>Motorola PTP600 - Receive Power (dBm)</name>
<graph>
<t_title></t_title>
<title>|host_description| - Receive Power (dBm)</title>
<t_image_format_id></t_image_format_id>
<image_format_id>1</image_format_id>
<t_height></t_height>
<height>120</height>
<t_width></t_width>
<width>500</width>
<t_auto_scale></t_auto_scale>
<auto_scale>on</auto_scale>
<t_auto_scale_opts></t_auto_scale_opts>
<auto_scale_opts>1</auto_scale_opts>
<t_auto_scale_log></t_auto_scale_log>
<auto_scale_log></auto_scale_log>
<t_auto_scale_rigid></t_auto_scale_rigid>
<auto_scale_rigid></auto_scale_rigid>
<t_auto_padding></t_auto_padding>
<auto_padding>on</auto_padding>
<t_export></t_export>
<export>on</export>
<t_upper_limit></t_upper_limit>
<upper_limit>100</upper_limit>
<t_lower_limit></t_lower_limit>
<lower_limit>-1000</lower_limit>
<t_base_value></t_base_value>
<base_value>1000</base_value>
<t_unit_value></t_unit_value>
<unit_value></unit_value>
<t_unit_exponent_value></t_unit_exponent_value>
<unit_exponent_value></unit_exponent_value>
<t_vertical_label></t_vertical_label>
<vertical_label>dBm</vertical_label>
</graph>
<items>
<hash_100013b40e5f664f33c8b6681896ecee8e5a21>
<task_item_id>hash_0800137d9a7090499e96ba2220b56b8db760d1</task_item_id>
<color_id>FFC73B</color_id>
<graph_type_id>5</graph_type_id>
<consolidation_function_id>4</consolidation_function_id>
<cdef_id>hash_050013d666215865788da79b77402a2a12e35d</cdef_id>
<value></value>
<gprint_id>hash_060013e9c43831e54eca8069317a2ce8c6f751</gprint_id>
<text_format>Receive Power</text_format>
<hard_return></hard_return>
<sequence>1</sequence>
</hash_100013b40e5f664f33c8b6681896ecee8e5a21>
<hash_10001370e29237b08c58c5715febaa9b2623b1>
<color_id>0</color_id>
<graph_type_id>9</graph_type_id>
<value></value>
<text_format>Current:</text_format>
<sequence>2</sequence>
</hash_10001370e29237b08c58c5715febaa9b2623b1>
<hash_1000135f118767c469a1af919a78b0eae24081>
<consolidation_function_id>1</consolidation_function_id>
<value></value>
<text_format>Average:</text_format>
<sequence>3</sequence>
</hash_1000135f118767c469a1af919a78b0eae24081>
<hash_100013101d2ba3d85496856b225c87a4e3b289>
<consolidation_function_id>3</consolidation_function_id>
<value></value>
<text_format>Maximum:</text_format>
<hard_return>on</hard_return>
<sequence>4</sequence>
</hash_100013101d2ba3d85496856b225c87a4e3b289>
</items>
<inputs>
<hash_090013c846a5d838ebf445522247e17965f1ea>
<name>Data Source [motorolaPTP600_rxdb]</name>
<description></description>
<column_name>task_item_id</column_name>
<items>hash_00001370e29237b08c58c5715febaa9b2623b1|hash_0000135f118767c469a1af919a78b0eae24081|hash_000013101d2ba3d85496856b225c87a4e3b289|hash_000013b40e5f664f33c8b6681896ecee8e5a21</items>
</hash_090013c846a5d838ebf445522247e17965f1ea>
</inputs>
</hash_00001304757f1c388446f9aebf3322068600e7>
<hash_0100135c549af2d29c746078d773f7a01e77fb>
<ds>
<t_name></t_name>
<name>|host_description| - Receive Power (dBm)</name>
<data_input_id>hash_0300133eb92bb845b9660a7445cf9740726522</data_input_id>
<t_rra_id></t_rra_id>
<t_rrd_step></t_rrd_step>
<rrd_step>300</rrd_step>
<t_active></t_active>
<active>on</active>
<rra_items>hash_150013c21df5178e5c955013591239eb0afd46|hash_1500130d9c0af8b8acdc7807943937b3208e29|hash_1500136fc2d038fb42950138b0ce3e9874cc60|hash_150013e36f3adb9f152adfa5dc50fd2b23337e</rra_items>
</ds>
<items>
<hash_0800137d9a7090499e96ba2220b56b8db760d1>
<t_data_source_name></t_data_source_name>
<data_source_name>motorolaPTP600_rxdb</data_source_name>
<t_rrd_minimum></t_rrd_minimum>
<rrd_minimum>-1000</rrd_minimum>
<t_rrd_maximum></t_rrd_maximum>
<rrd_maximum>0</rrd_maximum>
<t_data_source_type_id></t_data_source_type_id>
<data_source_type_id>1</data_source_type_id>
<t_rrd_heartbeat></t_rrd_heartbeat>
<rrd_heartbeat>600</rrd_heartbeat>
<t_data_input_field_id></t_data_input_field_id>
<data_input_field_id>0</data_input_field_id>
</hash_0800137d9a7090499e96ba2220b56b8db760d1>
</items>
<data>
<item_000>
<data_input_field_id>hash_070013fc64b99742ec417cc424dbf8c7692d36</data_input_field_id>
<t_value></t_value>
<value></value>
</item_000>
<item_001>
<data_input_field_id>hash_0700134276a5ec6e3fe33995129041b1909762</data_input_field_id>
<t_value></t_value>
<value>.1.3.6.1.4.1.17713.1.12.1.0</value>
</item_001>
<item_002>
<data_input_field_id>hash_070013012ccb1d3687d3edb29c002ea66e72da</data_input_field_id>
<t_value></t_value>
<value></value>
</item_002>
<item_003>
<data_input_field_id>hash_0700139c55a74bd571b4f00a96fd4b793278c6</data_input_field_id>
<t_value></t_value>
<value></value>
</item_003>
<item_004>
<data_input_field_id>hash_070013ad14ac90641aed388139f6ba86a2e48b</data_input_field_id>
<t_value></t_value>
<value></value>
</item_004>
<item_005>
<data_input_field_id>hash_07001332285d5bf16e56c478f5e83f32cda9ef</data_input_field_id>
<t_value></t_value>
<value></value>
</item_005>
<item_006>
<data_input_field_id>hash_07001392f5906c8dc0f964b41f4253df582c38</data_input_field_id>
<t_value></t_value>
<value></value>
</item_006>
</data>
</hash_0100135c549af2d29c746078d773f7a01e77fb>
<hash_0300133eb92bb845b9660a7445cf9740726522>
<name>Get SNMP Data</name>
<type_id>2</type_id>
<input_string></input_string>
<fields>
<hash_07001392f5906c8dc0f964b41f4253df582c38>
<name>SNMP IP Address</name>
<update_rra></update_rra>
<regexp_match></regexp_match>
<allow_nulls></allow_nulls>
<type_code>hostname</type_code>
<input_output>in</input_output>
<data_name>management_ip</data_name>
</hash_07001392f5906c8dc0f964b41f4253df582c38>
<hash_07001332285d5bf16e56c478f5e83f32cda9ef>
<name>SNMP Community</name>
<type_code>snmp_community</type_code>
<data_name>snmp_community</data_name>
</hash_07001332285d5bf16e56c478f5e83f32cda9ef>
<hash_070013ad14ac90641aed388139f6ba86a2e48b>
<name>SNMP Username</name>
<allow_nulls>on</allow_nulls>
<type_code>snmp_username</type_code>
<data_name>snmp_username</data_name>
</hash_070013ad14ac90641aed388139f6ba86a2e48b>
<hash_0700139c55a74bd571b4f00a96fd4b793278c6>
<name>SNMP Password</name>
<type_code>snmp_password</type_code>
<data_name>snmp_password</data_name>
</hash_0700139c55a74bd571b4f00a96fd4b793278c6>
<hash_070013012ccb1d3687d3edb29c002ea66e72da>
<name>SNMP Version (1, 2, or 3)</name>
<type_code>snmp_version</type_code>
<data_name>snmp_version</data_name>
</hash_070013012ccb1d3687d3edb29c002ea66e72da>
<hash_0700134276a5ec6e3fe33995129041b1909762>
<name>OID</name>
<type_code>snmp_oid</type_code>
<data_name>oid</data_name>
</hash_0700134276a5ec6e3fe33995129041b1909762>
<hash_070013fc64b99742ec417cc424dbf8c7692d36>
<name>SNMP Port</name>
<type_code>snmp_port</type_code>
<data_name>snmp_port</data_name>
</hash_070013fc64b99742ec417cc424dbf8c7692d36>
</fields>
</hash_0300133eb92bb845b9660a7445cf9740726522>
<hash_150013c21df5178e5c955013591239eb0afd46>
<name>Daily (5 Minute Average)</name>
<x_files_factor>0.5</x_files_factor>
<steps>1</steps>
<rows>600</rows>
<timespan>86400</timespan>
<cf_items>1|2|3|4</cf_items>
</hash_150013c21df5178e5c955013591239eb0afd46>
<hash_1500130d9c0af8b8acdc7807943937b3208e29>
<name>Weekly (30 Minute Average)</name>
<steps>6</steps>
<rows>700</rows>
<timespan>604800</timespan>
</hash_1500130d9c0af8b8acdc7807943937b3208e29>
<hash_1500136fc2d038fb42950138b0ce3e9874cc60>
<name>Monthly (2 Hour Average)</name>
<steps>24</steps>
<rows>775</rows>
<timespan>2678400</timespan>
</hash_1500136fc2d038fb42950138b0ce3e9874cc60>
<hash_150013e36f3adb9f152adfa5dc50fd2b23337e>
<name>Yearly (1 Day Average)</name>
<steps>288</steps>
<rows>797</rows>
<timespan>33053184</timespan>
</hash_150013e36f3adb9f152adfa5dc50fd2b23337e>
<hash_050013d666215865788da79b77402a2a12e35d>
<name>Divide by 10</name>
<items>
<hash_140013f658011daee32e2c2e5eeda6dafbcd81>
<type>4</type>
<value>CURRENT_DATA_SOURCE</value>
</hash_140013f658011daee32e2c2e5eeda6dafbcd81>
<hash_140013d567e27288f407710396ee6d2afe2719>
<type>6</type>
<value>10</value>
</hash_140013d567e27288f407710396ee6d2afe2719>
<hash_140013c24c0afb28cd87f156bff2a5dbb070e0>
<type>2</type>
<value>4</value>
</hash_140013c24c0afb28cd87f156bff2a5dbb070e0>
</items>
</hash_050013d666215865788da79b77402a2a12e35d>
<hash_060013e9c43831e54eca8069317a2ce8c6f751>
<name>Normal</name>
<gprint_text>%8.2lf %s</gprint_text>
</hash_060013e9c43831e54eca8069317a2ce8c6f751>
</cacti>
