Cambium force 300 automatically reset issue
i have force 300 . it is automatically reset in 4-5 days .
what is issue ?
how to resolve it ?
My guess would be that it “reset via power sequence” Sometimes when you have several power surges in a row, it will factory reset the radio. When you reprogram the radio, you need to go to Tools - Backup/Restore, Select “Disable” under Factory Default Configuration - Reset Via Power Sequence.
