cambium networks guest portal not working
When I connect to the AP I am not redirected to the portal
Are you using Cloud or On-premise?
Have you configured the correct guest portal in cnmaestro and pushed the config on AP?
       Please share the screenshot of the error. Some points to note :
Access any http website and check whether guest login page pop's up. (bbc.com)
Please make sure that the Guest Access Portal is saved in the cnMaestro.
Please share the AP techsupport to anv100@cambiumnetworks.com to verify your configuration.
if you are using cloud cnMaestro, please add me to your account, I'll check.
Regards
Anand
