Good Morning Guys! My SM Canopy Not Showing Out Device Type (Timing Master Or Timing Slave) Which Found On General What Can I Do To Figure Out These Options Which Help To Choose Whether Antenna Becaming Timing Master Or Timing Slave. Thank You
I have forwarded this to the support team
Alright Sir! Means That I Have To Wait Their Support... Thank You Very Much
Hi Benjamin,
Can you please share the part number of the PMP radio that you are using?
Regards,
Mohammad Arif Khan
@Benjamin1 wrote:Are Those Sir, On The Pictureππππππ
This is a PMP450 3GHz SM. It's not capable of being a timing master or slave.
Eric Thank You! But I Don't Think Its A Reason Why. Because Down Here On Pictures I Have Antenna Is The Same But It Has Those Options, And It's Work, But On This One Even I Select From Tools/OFDM Frame Calculator So I Choose Point-To-Point Link I Calculate Because There's No Save But Its Not Work And Chenged Itself To Multipoint Link. If There's Other Way You Can Help. Thank You
Hi Benjamin,
As per the part number (C035045C003A), this is a 3.3-3.6 GHz PMP 450 Subscriber Module that was keyed for SM (Point to multi-point) from factory.
Unfortunately, we cannot convert PMP450 SM to PTP450 BHM/BHS as itΒ is an end-of-life device type that can not be changed due to FPGA code locked.
And, the other radio part number (C035045B003A), It is aΒ PTP 450 3.5 GHz END that will have the option to configure it as timing master or timing slave. It is keyed for PTP backhaul from factory, so cannot be changed to Point to multi-point SM.
I hope it answers your query.
Regards,
Mohammad Arif Khan
Thank You Arif Khan!
So How Can I Differenciate Them (antennas) Before Connect a LAN Cable And Start Configuration, Simply On Physical Appearence For Those Antenna?
Thank You So Much Eric!
