A software defect in the TX2012R-P model may cause the Cambium Sync pulse to not be delivered to the attached radio. The issue will be resolved in the upcoming 4.2 release, available in early Dec. 2021.
The problem occurs only on the TX2012R-P model when Cambium Sync is enabled on an individual port or a group of ports. The problem does not happen when Cambium Sync is enabled using the ‘All ports’ option.
Please see the instructions below for enabling Cambium Sync on all ports of the TX2012R-P.
Using CLI:
config terminal
interface range gi 0/1-8
cn-sync output
end
Using Web:
Using cnMaestro:
