I try to restore a .bin config backup with :
snmpset -v2c -cprivate 10.1.1.254 .1.3.6.1.4.1.17713.21.6.4.20.0 s http://10.1.1.3/ePMP-backup.bin
and cambiumFullCfgRestoreError.0 indicates "Downloading file error"
But cambiumJSONCfgImport works as expected with :
snmpset -v2c -cprivate 10.1.1.254 .1.3.6.1.4.1.17713.21.6.4.1.0 s http://10.1.1.3/ePMP-backup.json
And manual (via webUI) updating using the same .bin file works.
PC local ethernet to defaulted SM.
j
Joel - The full config restore should work. The only reason we can think of is that the PC connected to your radio lost connectivity during this procedure. Can you please open a support ticket with our support engineers so they can take a look?
Did you ever get a solution to this issue? We are using 3.0.1 and have a nearly identical problem. However, in our case if we watch the cambiumFullCfgRestoreStatus variable we will see the download take place, then unpacking and then get a "Unpacking files error". However, as with you if we take that exact same bin file and simply apply it to the radio using the UI it works fine.
Hi Larry,
I would be really grateful if you could try it with last beta release 3.1-RC24.
I will check your case with 3.0.1 and will be back.
Thank you.
This did indeed work properly in the 3.1-RC24 firmware. Estimates on when 3.1 will be going live?
Thank you, Larry.
3.1 will be delivered in several weeks.
Thank you.
Any chance for a 3.0.2 that fixes this in the meantime. Not a big fan of running beta/RC on producion systems. Thanks!
Larry, we are doing our best to deliver release as soon as possible.
Sorry for inconveniences and thank you for you feedback.
Thank you.
http://community.cambiumnetworks.com/t5/ePMP-2000-and-1000/SNMP-triggered-binary-config-load-fails-3-0-1/td-p/60050 is the thread regarding this problem with 3.0.1 - For our purposes I wasn't too inconvenienced by this (yes, I started both threads) - the only time I typically push config file via SNMP is when defaulting newly-arrived units after updating them. So I just altered my script to update them AFTER pushing the config, and we've survived the problem with little impact. I realize that won't suffice for some, but a few weeks ago Cambium acknowledged the problem and have already fixed it, just awaiting final 3.1 release.
j
Missed that thread, but yes it works as expected in the 3.1-RCxx versions as you noted. We could change the automated radio setup script to push that first as well pretty easily, appreciate the idea.
Thanks!
