Answer: The ePMP Radio when configured as a Subscriber Module (SM) supports a RSSI and SNR threshold configuration. This allows the operator to set these targets and ensure that the installation meets a minimum RSSI and SNR threshold. The configuration can be found in the Configuration > Radio > Power Control section. The default value for Network Entry RSSI Threshold is -80 dBm. The default value for Network Entry SNR Threshold is 0 dB. Further information can be found in the ePMP user guide at https://support.cambiumnetworks.com/files/epmp
Below: SM Configuration > Radio page
