TodayI tried to putaePMP1000Connectorizedin the freezer. When itis icy,I try to power up using ahAPwith itsoriginal power supply Mikrotik (24V 0,8A). It can notstart with a 10mt cable.
With a 50cm patch it start.
I hear the hissof the thermal resistance
So, I need a 30V power supply for the hAP. Where I can find it?
I have been following this thread with interest. We're also doing a solar link with IP cameras to watch a protected habitat. We found what we thought would be the ideal POE switch from Veracity, the Camswitch Mobile, takes 8-30vdc in and will supposedly run any 12 or 24vdc POE device. We tried the Force 180 and it would not power it. We built the cross-over power cables (swapped the brown and blues) but it would not work. We ended up injecting 12vdc into the cable using the Cat5 part of a Canopy POE injector.
That got the 180 up and running. We have run the voltage down to 10vdc on the bench and it seems to run just fine. This is pretty encouraging for the solar site. I don't have time to rebuild it and move to 24vdc.
It seems that the smart POE switches have to "sense" the need for POE or else they won't output voltage.
Here's what we found after experimenting on the bench for a couple of days.
We whacked the injector off a Canopy and fed the Force 180 with 12.5 vdc, it worked a treat,as the 180 is evidenlty not 802.3af compatible. It was plugged into the Veracity switch which powered the POE cameras. Since the cameras were 803.2af/t compatible they worked fine. With this configuration we could run the supply voltage to both the Force 180 and the switch down to a little over 10vdc and they kept working, in fact we ran them for 30 hours on the bench at 10vdc. If the voltage went lower they would drop out but would come back up when the input went back up above 11.5vdc.
We also tested an Ubitquity Instant 802.3af adapter (POE to passive) to run the Force 180 from the switch. That worked just fine, too. However, we found that the whole system dropped out just under 11vdc with the Ubiquity in the mix so we pulled it and put the injector back in line.
The whole system, (2) Alibi IP cams, the switch and the Force 180 pull about 850ma at 12+ volts so we're pretty happy that this will work on our solar powered system. We have an 85 watt panel and a honking big battery. HTH.
If you're in an area that goes below freezing, Run one more test. Put the radio in the freezer and let it cool down. Issue a reboot and see that the system remains up.
That is unless you are in an area that does not freeze...
I love the angle of your cute little solar panel. It is almost like the sun always shines there, and almost like you live directly under the sun or something! LOL. Looks beautiful.
We, on the other hand, almost have to point our solar panels down over the horizon. And we need a bit more wattage than you do there. Remind me again why I live in Canada?
The litle stand shows 2 of the 4 - 100 watt panels that we were pulling out, and replacing with the new array - which is 4 panels, each 240 Watt @ 24Volts. YES - we trimmed that tree back before we left. :)
Sri, I didn't look at how much bandwidth the cams took. We have a 60mbps uplink shooting about 3 miles across the harbor to a Force 200 dish. Yes, both cams are fed to the Force 180 through the Veracity switch. Remember, we are not powering the Force 180 from the switch, just the cams. Powering the Force 180 directly. I can run some numbers on it next time I'm at the head end.
Nine, talk about a low angle, sheesh. None of this sun directly overhead for you, eh? We are in the middle of SC on the coast so we get good sun. I think they're set about 60deg.
That's also to help keep the snow off them a bit here. They are not ideally tilted enough for the Summer, when the sun it higher in the sky, but they still get enought light in the summer anyways - so that's not as critical. They are tilted low to maximize light in the winter, when our sunrise/sunset times are about 9:15 AM/4:45 PM
And if we tilt them up any higher - this is what happened to the old 4x 100 watt pannels in the winter. :( So, lower angle works out generally better for all year and not having to move them up and down, and not having to go clean them every few days.
