Is there a way to schedule firmware updates for a specific time, or do we have to put the updates in the Active Jobs queue and then manually start them at the desired time?
I'm not sure which application you are refering to, but if you are using CNUT then we have an option of Scheduling the Radio software upgrades under Update >> Schedule Network Update. So that you can specify a schedule activity.
Regards,
Sanjay Kumar
I should have clarified. I'm referring to updating the cnPilot R200 through cnMaestro. Can these devices be upgraded through CNUT as well?
I am not sure if we can use cnut to upgarde the R200, I will have to check on that, however; we do have an option of auto-upgrade.
You will find all the information on the user guide on chapter 3-81 and from page 3-84.
Here is the link to dowload the same:
https://support.cambiumnetworks.com/files/r200/archive
Regards,
Hardik Patel
