Cannot select 15/20MHz channel widths on PMP450i 900MHz
I'm pretty sure this is a bug, as I remember being able to select 15/20MHz channel widths in the past, but as of 16.0.0.1 you can no longer use these channel widths. Strangely enough, I have a PTP450i 900MHz link that's running 16.0.0.1 and I can use 15/20MHz channel widths no problem. I've confirmed this with some other users that are reporting this issue as well on FaceBook.
Looking into this now...
Eric-  I just checked 15 and 20 MHz bandwidth on my lab setup and it worked.   I will contact directly to collect information on your radio and mine to look for a difference.
Dave
Cambium tech's were able to verify this issue with my radio and a bug fix is scheduled for 16.1.
The current work around to use 15/20MHz channels is as follows:
- Change the Center Frequency to a valid frequency for the Ch BW you are going to select. Do not change the Ch BW at this point.
- Save the config and reboot the radio.
- Once the radio is up, now change the Ch BW to the desired value.
Thanks Eric, for pointing out this issue.
