Does anyone have specs for use with Radio Soft on the 900 AP’s?
ERP, watts, antennae gain.
Thanks in advance
Reay Culp
It’s on the spec sheet but here ya go:
Integrated and Connectorized Tx Power = 26dB
Integrated Antenna Gain = 12.5dB
Integrated Antenna Pattern = 60H x 40V
Integrated EIRP = 4W
Thanks Jerry,
What about Antennae ERP?
Can it be found by:
4W + 12.5 db Gain - losses in Db = Antennae ERP
36dB or 4W ERP is the max for 900
Tx power + antenna gain - cable loss = ERP
