when i use advantage ap communicate with 5700SM, i found its latency is also 20ms, not 5-7ms, why ?
are you alredy using h/w scheduler? by default ap advantage use s/w scheduler so if you connect 5700sm to 5700ap without enable h/w scheduler, the latency still 20 ms
regards,
mrdlnf
“…cut
connect 5700sm to 5700ap without enable h/w scheduler…” --> sorry wrong p/n
should be :
"…connect 5700sm to 5750ap without enable h/w scheduler…"
regards,
mrdlnf
mrdlnf wrote: "..cut
connect 5700sm to 5700ap without enable h/w scheduler.." --> sorry wrong p/n :-D
should be :
"..connect 5700sm to 5750ap without enable h/w scheduler.."
regards,
mrdlnf
but P7 and P8 chip have no H/W, only P9 has H/W? really?
You can enable h/w scheduler on SM via CNUT.
In Tool Option, there is Advantage Platform H/W scheduler tools. If you using 7.2.9 u must use the new tool (new jar files) for enable h/w scheduler
regards,
mrdlnf
