hs anyone seen a part number for replacement u bolts for the dish. They only come with the dish if you buy it as a backhaul and there is no way to mount the same dish on a pole or pipe if it is purchased as an SM accessory. DUH
I believe P/N BH-1209 is what you are looking for.
