Congratulations.
Great work. I find it quite useful.
Congratulations.
Thanks. Fantastic ideas. Good job.
Thank you, this extension is awesome. I think Cambium should consider just implementing much of what you have done into their software
after the update i can see no more the real time traffic (both graph and string).
(Firefox)
Thanks!
@Telemarwrote:Hi,
(Firefox)
Thanks!
With Version 1.8.14 it's all ok!
Updated to 1.8.14.1 but same problem...there's not graph real time traffic (graph is blank).
String works well.
Thank you Tuvix
Thos doesnt seem to work with luid throughput 450ap. Use to until recently? Anyone else?
With 1.8.15 the graph works very well and the entries are very useful!
Thank you!
can you also make a canopy gui enhancer Extension for microsoft edge?
@1979 wrote:can you also make a canopy gui enhancer Extension for microsoft edge?
I'll take a look if Edge supports all Web Extensions APIs used in CGE :)
@Tuvix_IT wrote:Hi, firmware with firmware 15.2
In Data Channel there are negative numbers.
Also in 15.2.1 firmware
Thanks, It should be fixed in 1.8.16
I like that you have .css LMAO
Chrome extension isn’t working any more looks like the firefox and edge version is still working.
It’s working here.
What isn’t working and what Chrome’s version are you using?
