Hello.
I have a client who has a farm and he wants cctv in the farm.
I want to suggest cambium epmp for transmission of these cctv footages.
Which cambium product js good fir this
Depending on the number of cameras and the specific requirements, but we currently have a few sites including our towers with IP cameras on them. Some with many cameras have a local nvr others with just a couple we carry the data back to a nvr.
No problems with epmp hardware, cnvision is just epmp with different firmware to prioritize video streams and take out things that are not needed for a wide area closed and non-shared cctv network.
Remember to calculate for both the high def stream and the low def stream if you are not using a local nvr, else just multiply the number of cameras by the low def stream rate plus one high def stream rate to figure the upstream bandwidth needed.
If you run a wisp and are going to carry this data, you may want to either setup a vpn access or a ptp-tunnel from one site to another.
