@David_Aneas wrote:
The range its between -30 and +27, when I run the script, the parameter Max tx power not change.
I try with 21,23,27 but nothing works. Only the part of SNMP.
I dont need to change it on the antenna menu, i need to make it work on the script because I tried to changed a few times but doesnt work.
David,
Under whisp SM Config there is the OID "maxTxPowerEnable" (.1.3.6.1.4.1.161.19.3.2.1.160.0) that MIB description says:
Enable Max Tx Power configuration.
This is used with OID maxTxPower to set the max transmit power.
This might be required in certain regions and frequency bands.
See User Guide for more information.
Enabling this will not allow a radio to transmit above its EIRP limit.
The AP's Transmit Power Control may still adjust the Tx power down.
SM only.
So "maxTxPower" (.1.3.6.1.4.1.161.19.3.2.1.161.0) SM's OID description reads:
This OID is controlled by OID maxTxPowerEnable.
See user guide for more information.
Setting this will not allow a radio to transmit above its EIRP limit.
SM only.
Does it work when you manually change it in SNMP? That might be good to check.
Then the only issue left would be configuration file. What I suggest is making the change manually and then downloading your Configuration File (Configuration -> Unit Settings -> Download Configuration File). So I did this and see this as part of the config file:
"smRadioConfig": {
"powerUpMode": 0,
"frequencyScanList": [
5760000,
5770000,
5780000
"maxTxPowerEnable": 1,
"apSelection": 0,
"maxTxPower": 24,
"bandwidthScanList": [
100,
200,
400
Does any of that help?
On a related question, why are you capping your SM's Transmit Power?
