Product: ePMP-1000 in Standard WiFi Mode
Software Version: 2.6.2
Minimum configuration required on the AP:
- AP Mode: Standard Wi-Fi
- WLAN enable: Enable
- SSID name: Cambium-AP or any
- Authentication Method: Open or WPA2 (key should match/same between the AP and clients)
- Radio Channel Selection: Need to be selected as per the below link.
http://www.radio-electronics.com/info/wireless/wi-fi/80211-channels-number-frequencies-bandwidth.php
- Make sure we have selected 20 or 40 MHz bandwidth
Incorrect channel frequency was selected (example 5695 MHz). This 5695 MHz channel frequency is a in between frequency. Normally, the Wi-Fi client devices such as phones and laptops will scan only for the certain channel frequencies.
Solution:
Selected the correct channel frequency (example 5825 MHz) which is in the scan list of all the Wi-Fi client devices.
