On 2 of 2 cnMaestro cloud instances I have some, but not all showing incorrect power level as well as incorrect sync status. Some APs have both correct, some have 1 incorrect, and some have 2 incorrect.
To cover the bases I opened a ticket, but don't expect much.
@tarball, are you able to disable and then enable the AP's network connectivity to cnMaestro? I'm looking to clarify if the correct values are displayed in cnMaestro once the AP re-registers.
Thanks for asking the question. All APs are now showing the proper transmit power and sync status.
Since both of these systems were previously running against on-site cnMaestro and since both exhibited the problem shortly after the migration to cloud cnMaestro I would bet there is a problem when they get onboarded from a running on-site cnMaestro. Just a guess for my programming decades. Might want to check that out in the lab. I can say for sure the problem was visible for a few days after the migration, but it obviously got cleared by something.
Re-reading my answer, I think it could be interpreted that I may have followed your advice and re-onboarded the APs. All I did was check the current status. And they had changed to the correct state.
