I talked with Mr. Sexton on the phone and he said the ends of the gps cable are both female. On the CMM-Micro user manual, it only tells you the type of connector, and what type of cable you should use. (LMR195) The invoice from SFD Inc who makes our cables says:
RFB11062 BNC Male Crimp-on RG58U
RFN10052 N-Male Crimp RG58U
Nevermind… 4.1.2 Page 22.
