I have a 6 - unit cluster (900) with a CMM (1070CKBD) and i want to add 3 -5.7 120 deg units … can i daisy chain 2 CMM’s or do i just add another GPS antinna?
add another antenna
mikemews wrote: I have a 6 - unit cluster (900) with a CMM (1070CKBD) and i want to add 3 -5.7 120 deg units ... can i daisy chain 2 CMM's or do i just add another GPS antinna? Thanks
If you want to have all the ports on a CMM ( meaning you want to hook up just like a CMM) then you need to add a CMM or other Sync Device.
If you are wanting to be cheap, you can use a standard canopy power supply to power the new radios and then daisy chain pins 1,3 and 6 from an existing radio to the new ones on the sync port. Or, the last part said differently - pins 1, 3, and 6 can be paralelled across a few radios from one port on the CMM.
-forrest
