Hi there,
I have 4 AP conected to a CMM, and I keep getting a very weird problem; 2 or 3 times a day, the 4 AP’s that I have conected to the CMM stop working.
It is weird, if I check the status of the CMM, it show that all AP’s are operational, but if I try to ping the AP’s, none of them respond, and of course all my clientes are down.
The AP’s have been working perfectly for about a year without a CMM
Has any one had this type of problem? Any Ideas on what it could be?
Adolfo
I had a similar problem when someone came in our area without a cmm
Check out the following:
- Is DFS kicking in? That will stop the radio from working for 30 min if it detects a radar pulse on the same frequency as it.
- Is it losing sight of GPS satellites? If that happens on a CMM Micro then it stops generating a timing pulse.
I just happend again, and this is what i got from the log:
Event Log
11:15:59pm : Sat Apr 01 2006 : File syslog.c : Line 490 System Log Cleared
01:34:25am : Sun Apr 02 2006 : File httpd.c : Line 3229 Reboot from Webpage.
01:34:25am : Sun Apr 02 2006 : File syslog.c : Line 785 System Reset Exception – External Hard Reset WatchDog
01:34:25am : Sun Apr 02 2006 : File …/cmm/root.c : Line 69 CANOPY CMM 2.1.3 Jun 22 2005 13:54:15
01:34:39am : Sun Apr 02 2006 : File gps.c : Line 437 GPS Date/Time Set
01:34:57am : Sun Apr 02 2006 : File gps.c : Line 678 GPS SYNC Pulse Detected
12:35:24am : Sun Apr 02 2006 : File httpd.c : Line 3896 Idle web socket found
03:49:44pm : Sun Apr 02 2006 : File httpd.c : Line 3896 Idle web socket found
