CMM uplink port
Hello,
I just installing a CMM with four BH modules connected to it. My question is what kind of ethernet cable should I use to connect the CMM to my network ? I know that I should connect the uplink port, but I’m not sure if I have to connect it with a straight ethernet cable or a crossover.
Thanks.
Most all networking equipment is auto-sensing now-a-days so it shouldn’t matter, but I believe that the uplink port is internally crossed, so it would all depend on the type of port on the other side. If it’s a regular LAN port, use a straight through cable.
