HI,
I am looking for a diagram for the cable to connect a CMM5 to UGPS.
Paul
HI,
Paul
It is in the CMM5 manual, look at page 2-21. Hope this helps.
Nice job Clay... I emailed Paul back with exactly that response as well.
For reference, a straight-thru 6-pin RJ11 cable works to connect the CMM5 to the UGPS.
We also offer a 20 meter fully shielded pre-made cable if desired, part number: N000000L103A
Hi does anyone have a picture of this cable i just need to see what it looks like when done so i read up its straight throuhg cable RJ-12 CONNECTORS on both ends so if anyone can just post a picture just to clarify
thanks
I looked at that page in the manual and my UGPS. I don't have a sync out on the antenna. What I see are Aux Sync, ODY Sync and PIDU Sync
Aux Sync, ODY Sync and PIDU Sync ports or on a cnPulse. The uGPS has one POE port and 2 Aux ports. Attached are pictures of a uGPS Aux port or cnPulse Aux port to CMM5 cable. It is a 6 pin straight through. I also have the pinouts attached
