CMMicro as a Switch
I have a cmmicro at one location. Pulgged into it is 3 cyclone 5.2 120 degree ap’s feeding 20 sm’s. All are working great, but I am using a redline an-50e to backhaul to this location. My question is, can I plug the an-50e into a non-powered port on the cmmicro, so I can remove my managed switch from the equasion?
This is correct, you can turn power off on any port and just use the switching funtionality. Everything will depend on what you are using your managed switch for though - the CMM will just act like a standard switch.
Aaron
