Hello to all
Do you noticed that cnmaetsro might have the correct value on the power of the AP transmit power and sometime show -25dBm?
Do you have any answers given before by cambium on this matter?
Hello to all
Hi gkounis.
Can you clarify the AP family (i.e. ePMP, PMP, cnPilot E or R) and also the software version your these devices are running? Also, what version of cnMaestro are you running. This is displayed on the bottom of your cnMaestro page.
Are you seeing this problem on a single device or many AP devices? Does the device user interface show the correct AP Tx power? If your AP is using an external antenna, is your antenna gain set correctly on the device UI?
Emilio
