Hi Team,
What is the wifi maximum speed and throughput on CnPilot E400
Regards.
Esakki.K
Hi Team,
Regards.
Esakki.K
I connect my laptop to CnPilot E400, but the wifi speed shows 72 Mbps only why ?
If i connect another product like ruckus or TPLink it shows 150 Mbps.
My laptop is b/g/n supported.
I changed the channel width as 40 Mhz, still it shows 72 Mbps only.
Pls clarify.
Esakki
The throughput number is the maximum aggregate throughput for multiple users, and considers the source broadband connection. I am forwarding your note to our support team so they can give you the details.
@Esakki wrote:
Pls clarify.
Esakki
Looks like the client is either connecting in 1x1 mode, or adjusting its rate down to 72Mbps. Can you please email us a tech-support from the access point, along with details of the client (what client-card and driver version if possible) to support@cambiumnetworks.com?
you can download the tech-support file from the device GUI under 'Operations'.
I sent the tech-support to support@cambiumnetworks.com.
Pls go through it and guide me.
Esakki.k
Team,
I sent the tech support file to support@cambiumnetworks.com.
Did you got it ?
Pls guide me.
Esakki.k
Esakki,
Unfortunately, we did not receive it.
Please email tech-support it to shashank.tadakamadla@cambiumnetworks.com.
Thank You.
Essaki,
I did not find any discrepency in your configuration. However could you please configure "Radio 1" to 20MHz.
Could you please provide more details of your wireless client?
Thank You.
Hi shashant,
I will provide remote access, can u pls check it by tomorrow 11 am.
Pls confirm.
Esakki
Hi shashak,
Thanks for your remote support , i will check with another laptop which is supported with 2x2. and update you soon.
Also will check with Ruckus, once it available from my customer.
Esakki.k
As per the remote session, below are the observations:
