- Please enable use of mouse scroll wheel on all map items... currently only works for maps used for initial placement.
- Please add DL/UL frame utilization to the stats for radios please.
- Mouse over detail for graphs that show over time stats.
Eric,
During on-boarding of an SM, cnMaestro will not ask you to select "Network" or "Tower". These are automatically determined based on which AP the SM connects to. I suspect this is what you saw. If not, please let us know.
There is already an enhancement request in place to rename the "default" Network object (CNSSNG-2098) so it will come, just not in the next few weeks.
ePMP in PTP mode is not yet supported. We will update the release notes to explicitly state this. Right now, it just says ePMP AP and SM are in beta, which is not clear enough. Sorry about the confusion.
We are working on simplifying the on-boarding of SMs. You will be able to see the SMs connected to an AP and on-board them from cnMaestro teself without having to login to the SM. Stay tuned.
Regarding "UI idiosyncrasies", please provide more specifics when possible. Do note that under "Manage > Organize", you can create and manage Networks and Towers, but to actually move devices between them, you have to select the device and then go to "Configure > Devices". You currently cannot move a Wi-Fi AP after on-boarding, but this will be fixed. You also cannot specify a Network and Tower dor SM, this is determoned automatically. Those are the "idiosyncrasies" I am aware of.
We will add the ability to view release notes for cnMaestro.
Making the "beta" an explcitit opt-in is a good idea. I have added this request to our backlog (CNSSNG-2275).
I will follow up on the request for frame utilization stats.
Keep the feedback coming.
