Hello,
There seems to be some user-interface issues with configuring the Active Directory authentication servers.
1) When you pick SSL/TLS Security (during add or edit), and select the certificate file to upload, the interface will respond with a red box that states the certificate file is required (when it was supplied)
2) When you edit a server, and the entry has SSL/TLS Security OFF, the UI still shows the file selector for the certificate even though it is not needed. If you attempt to save, it will tell you the certificate is required. The workaround is to select and then de-select the SSL/TLS Security checkbox before saving.
When testing the connect, WHY are there 3 boxes to test authentication (User Id, Password, and Account) ? A true test should only have 2 boxes (User name and password) to match the 2 boxes that are shown during normal login to cnMaestro... What 3 values should I be putting in there? No matter what I do to test, I always am told the credentials are wrong even though I am using the same configuration for authenticating as I do with all our linux machines on our network (using SSSD under linux works fine, so I know my setup should be valid)
