cnMaestro 1.6.0 Release
Telemar, devices that are not synchornized with the AP group should show "Not In Sync" in varirous places in the UI.  The easiest way to see a list of all these devices is to go to the Application -> Sync Configuraiton section.  This will list all out of sync devices and allow you to select them all and sync them by clicking "Sync Now".
Are APs with the Autonomous option showing "Syned" even if their AP Group is using Centralized?
Just wanted to follow-up on the issues earlier in the thread with vmiskos and michelep. Seems both accounts are having problems logging into cnMaestro 1.6.0 On-Premises after a period of time -- requiring a reboot (which solves the problem). While one of the accounts is somewhat high on memory, we suspect it is not the reason for the login failure. Anyway, we are hoping to get technical support logs, so we can get a better sense of what is going on and prioritize a fix.
Perfect Jordan. Now the AP's are alla Synced and inside the AP I can see the Centralized option selected.
Thank you!
Hello.
We  have encountered an API bug.
When we GET
/api/v1/devices?fields=ip,mac,type
API doesn't return ip - only mac and type are present in response.
This happens with any combination of 'fields' that include 'ip' - seems like this field was left out...
If we GET
/api/v1/devices
ip field is present in response.
We are using CnMaestro 1.6.0-r5.
Is this a known issue? Is there a fix?
Hi Dronskii
This is a known issue and has been adressed in 1.6.1 which will be released soon.
Regards,
Rupam
When i try to override a VLAN2 config from DHCP to Static in AP -> AP_NAME -> Device Overrides (Advanced) -> Others Vlan i got error:
Body data not provided for device config level update
AP is E410 with lastest firmware.
Hi carlosmilek,
We are aware of this issue and have fixed this in the next releaes, 1.6.1.
Our server needs reboots frequently but now nginx will not even start up.  We cannot get it going.  It started off simply as SNMP not working.  We couldn't actually probe the server.  I verified snmpd was running etc but it wouldn't respond.  This morning web gui was blank.
We are getting some sort of "unknown directive "upload_progress" in /etc/nginx/conf.d"  errors.
So it looks like a nightly update is what borked the server.  I could restore from backup but then the next nightly update will screw it up again.
Anyone have a solution?
Hi Steven -- I am not sure what a nightly update is. Is this something added to the underlying OS?
hi, any update on the release of 1.6.1? thanks!
It is getting annoying having to reboot these servers routinely.  I'm almost considering putting in a cron job just to reboot it every night.
yes, i have configured a night reboot on vSphere.... :(
Also having an issue with our on-prem server requiring a reboot.  Has been happening daily since we migrated to 1.6.0, except for on the weekend.  For now we can just schedule a nightly reboot, but it would be nice if this were fixed in the next release.
hello, can you please send me a private message with tech dump?
Do you have an email address I can send the tech dump to? I tried sending it to you via PM last week but i can't appear to attach a file other than an image.  This issue has changed somewhat for us, at first the server was fully unreachable until a reboot, but now it lets me get to the login screen, just doesn't let me login (Believe this is closer to the issue others are having).  Checked the performance on VSphere and I see 85% RAM usage.  Reboot has once again let us login.
