"Statistics" page not displaying "Uplink RSSIIImbalance" nor "Uplink RSSI". Maybe it's already being imported from the AP along with "Modulation (UL)" and just not being displayed.
It would be great if you added them after "Modulation (UL), in the listed order, and label both the current RSSI fields with (DL).
"Performance" report not exporting "Uplink RSSI (dBm)" nor "Uplink RSSIImbalance"
That is right. Even for recurring job, we have added a Download option on the Jobs page itself so that you can download the latest copy from there without going to Job History.
Thanks for detailed feedback. We will add "Status Time" to statistics table export and also print the MAC Address in a separate column. We will also add "Session Time" to Devices Report for SM devices. "Status Time" is already there in Devices Report as "Uptime/Downtime". We will rename it to "Status Time" to be consistent with other places.
As far as scheduled daily/weekly reports are concerned, your expectation is correct, you should be able to download the report for each occurrence. Currently retention period for these reports is 1 week. Post that report files will be deleted from server. You also have provision to upload these files to a remote FTP/SFTP file server. You can configure remote FTP/SFTP file server at Application > Settings > Optional Features > Scheduled Jobs. Please refer to User Guide for more details.
..."Status Time" is already there in Devices Report as "Uptime/Downtime". We will rename it to "Status Time" to be consistent with other places.
-Ajay
Edit: We will also add "Session Time" to Devices Report for SM devices.
Sure wish I could read and comprehend!
I thought maybe this was it, but then since it's "Uptime/Downtime", I thought it may be it was "Online/Offline time. If it's "Session Time" then maybe remove "Uptime/Downtime (Seconds)" and replacing with "Online/Ofline Time" might be better. I don't see a need for time in seconds, but someone else may.
And there was no mention of "Statistics" page not displaying "Uplink RSSIIImbalance" nor "Uplink RSSI"
Also, it would be nice to be able to toggle/select Imperial/Metric options.
When you say export data , which data you are exporting and what is the exact problem can you please give some more details so that we can check and get back on this.
We tried locally to reproduce in GMT+5:30 IST timezone and we are not seeing the issue with events report. Can you please confirm whether your timezone has any day light savings currently .
Also is the Events report downloaded using the NOW option or scheduled using Daily or weekly option. Is it scheduled during Day light Savings or earlier.
Also please check if there is any difference in the cnMaestro server time(Can be seen from serve rcommand line interface ) shown and the time in laptop or machine where the cnMaestro is launched in the browser.
Why i am asking is the GUI shows the timings based on the browser laumched machine and the Reports sceduling or timings are based on the Server timings.
cnMaestro changed time this weekend, so it looks like the coders decided to split the difference between the Americas and European time change dates. Americas - second Sunday in March, Europe - last Sunday in March.
Regardless, I would expect something like TIME to be the same whether displayed or exported, otherwise the data doesn't mean anything. I've been trying to point this out since the original release of cnMaestro. Current Weekly Usage graphs fill in at midnight UTC NOT local, so what does that data really mean? It's a pretty screen filler, I guess. Pick a time and stick with it for ALL timestamps - Even if it's "Wrong", at least all the data will correlate. If one piece of data is called into question, all the data is suspect.
Yes. We will add it as part of 1.6.3, scheduled for release by end of March.
-Ajay
So will the PMP SNMP Site Contact and Site Location fields be added to the AP/SM dashboards and as searchable fields in inventory in a future 1.6.3 release?
