CnMaestro 2.2 onprem HyperV conversion
I would like to just post for anyone looking to convert the CnMaestro VM into a Hyper-v based VM, you can follow the previous steps here: https://community.cambiumnetworks.com/t5/cnMaestro/cnMaestro-NOC-Installation-on-Hyper-V-of-Windows-2k8-Server/td-p/78369?nobounce
However, to get the latest version to work in Hyper-V, you 'll need to understand that the latest CnMaestro image contains two virtual disks.  Convert both the vmdk files and add them both into your Hyper-V VM.  You have to have both disks in the VM for CnMaestro to work properly.  Just thought I'd pass this on.
Thanks for the info, I’ve manage to add the second disk after the installation, is there a way to add it during the installation as it seems not tobe working.
Any advice will be helpfull since I got this err…
“An exception of type CnException occured. Arguments: (”(network.py:264) read network config filed: [Errno2] Nosuch file or directory: ‘/srv/storage/etc/cnmaestro-network.json’ ",)
