Introduction
This document highlights new features in cnMaestro On-Premises.
Important |
cnMaestro 2.4.1 On-Premises is distributed as an OVA file, which can be installed as a new Virtual Machine or used to update an existing installation running with 2.3.0/2.3.2/2.4.0 OVA. |
Important: Web Browser |
You may need to restart your browser (or clear the browser cache with a hard reload) after the 2.4.1 update. |
Support for SAS Vendor CommScope
Support for new CBRS SAS vendor CommScope is added. It is available at Services > CBRS > Account page.
Time Zone Setting
Support for the Time Zone setting is added to localize the timestamps captured in Email/Webhooks notifications and RESTful APIs. It is available at Application > Settings > General page.
Enabling SSH Access through UI
Support to enable SSH access to cnMaestro Server is added. It is available at Application > Server > Settings page to users with Super Administrator role only.
Machfu Support
cnMaestro supports the following monitoring and management functionalities on Machfu.
Feature |
Details |
Onboarding |
Onboard Machfu devices using MSN or Cambium ID. |
Dashboard |
Device level Dashboard for Machfu. |
Notifications |
Machfu specific notifications and alarms. |
Performance |
Performance graphs with the following metrics: Cellular Throughput, Cellular RSSI, CPU Load, Disk Storage, Ethernet Throughput, Flash Memory, Wi-Fi Client/Access Point Throughput, Wi-Fi Client RSSI |
Operations |
Device reboot. |
Software Update |
Bulk software update. |
Data Report |
CSV based Data Reports. |
Machfu Dashboard
Machfu Performance
API Updates
Update Notice for Existing APIs
Path |
Details |
Devices API |
/api/v1/devices/ |
· New properties named cbrs_state and cbrs_status have been added. These will be available only if CBRS is enabled. |
Supported Cambium Products
cnMaestro supports the following Cambium Networks products. The software versions are the minimum required to use cnMaestro (not the recommended versions).
Family |
Model |
Version |
cnPilot Home |
cnPilot R200, R200P |
4.2.3-R4 |
cnPilot R201, R201P |
4.2.3-R4 |
cnPilot R190V, R190W |
4.3.2-R4 |
cnPilot R195P |
4.7 |
CnPilot R195W |
4.5.2 |
Enterprise Wi-Fi |
cnPilot e400/e500 |
2.5.2-r3 |
cnPilot e410/e430w/e600 |
3.5.2-R4 |
cnPilot e501S/e502S |
3.2.1-r6 |
cnPilot e700 |
3.8 |
cnPilot e425/e505 |
4.0-r17 |
cnPilot e510 |
3.11.4-r9 |
XV3-8 |
6.0 |
XV2-2 |
6.1 |
ePMP 1000 Hotspot |
ePMP 1000 Hotspot |
2.5.2-r3 |
ePMP |
ePMP 1000, Force 180/200 |
2.6.2 |
ePMP 2000 |
3.0.1 |
ePMP Elevate XM/XW |
3.2 |
ePMP Force 190 |
3.5 |
ePMP Force 300 |
4.1.1 |
ePMP PTP 550 |
4.1.1 |
ePMP MP 3000 |
4.5 |
ePMP PTP 550 E |
4.4.2 |
ePMP Elevate SXGLITE5 |
4.3.2.1 |
ePMP Elevate LHG5 |
4.3.2.1 |
ePMP 3000 |
4.4.1 |
Force 300-13L |
4.5.2 |
PMP |
PMP 450i, PMP 450, PMP 450m, PMP 430 SM |
15.0.1 |
PTP 450, and PTP 450i |
15.0.1 |
Micropop Omni/Sector |
16.2.1 |
Retro |
16.2.2 |
PTP |
PTP 650 |
01-47 |
PTP 670 (650 Emulation) |
01-47 |
PTP 670, PTP 700 |
02-67 |
cnReach |
N500 |
5.2.17e |
cnRanger (Beta) |
Sierra 800 |
1.0.1.0-r1 |
Tyndall 101 |
1.0.1.0-r1 |
Machfu (Beta) |
Machfu |
7.1.2-1.1.0.5 |
Supported Browsers
cnMaestro supports the following browsers:
Platform |
Browser |
Version |
MS Windows |
Internet Explorer |
11 and above |
Microsoft Edge |
44.17763.1.0 |
Firefox |
45 and above |
Chrome |
49 and above |
MacOS |
Safari |
9 and above |
Linux |
Firefox |
45 and above |
Chrome |
49 and above |
Significant Fixes
The following issues have been fixed:
Id |
Details |
CNSSNG-12167 |
Wrong Passphrase is getting pushed to AP in WLAN Group. |
CNSSNG-12455 |
MAC Address format should be unique in all configuration parameters. |
CNSSNG-13171 |
Improvements to Spectrum Inquiry Response graph in Tools. This release now shows the height of each bar in the graph proportional to the EIRP, if that information is provided by the SAS vendor. |
CNSSNG-14173 |
CBRS Management Tool better displays info on operational parameters in SAS responses. This includes a new column in the tool to show “SAS Recommended EIRP”; printing related text via hover over bubble; and the ability to request the SAS recommended EIRP by clicking on the START action button. See the CBRS Consolidated Procedures Guide for more information. |
CNSSNG-14798 |
Option to set time zone from cnMaestro UI (On-Premises Only) |
CNSSNG-15160 |
Enable/disable SSH access from cnMaestro UI (On-Premises Only) |
CNSSNG-15250 |
Improvements to CBRS heartbeat interval and timeout handling. |
CNSSNG-15251 |
Separate billing and technical contact information requested on CBRS Services Accounts page of cnMaestro, instead of a single set of contact information. |
CNSSNG-15256 |
A Reimport option has been added to the CBRS Management Tool spreadsheet import function. If, for example, an operator made the same configuration mistake on every device in a sector, previous options were to edit every device one-at-a-time via pop-up GUI or delete everything and re-add with a new sheet. Now operators can use the Reimport function to change installation parameters or EIRP in any state, although a deregistration will be triggered. Changing BW or Center frequency is also supported via Reimport, but only if all devices in the sector are deregistered prior. |
CNSSNG-15258 |
The CBRS Management Tool supports live status updates of the CBRS state of the radio. Prior to 2.4.1, the CBRS state of the device was frozen after the device flips to config_sync state. Now this field, as well as others, are updated from the device. See the cnMaestro Cloud User Guide for additional details on live status updates. The CBRS Management Tool supports an Export function to recreate the spreadsheet based on current tool entries. The CBRS management tool also supports ODS file format for import instead of just Excel. Note export to ODS format is not yet supported.
Editing EIRP for Config_synced devices is supported from cnMaestro, rather than just directly on the devices. See the CBRS Consolidated Procedures Guide for more info.
The CBRS Management Tool now allows editing parameters for devices in Not_Synced config states other than deregistered/unregistered -- i.e. one can edit parameters in an AUTH/Not_synced state although a deregistration is forced by cnMaestro as part of the edit. |
CNSSNG-15259 |
cnMaestro Reports generate CBRS related data. |
CNSSNG-15525 |
With 2.4.1, removing devices from CBRS Management Tool no longer deletes them from cnMaestro inventory/onboarding queue. CBRS Tool replaces the old method of Deregister per device via checkbox with Delete and Deregister action buttons near the top of the tool. With this improvement, “Deregister All” and “Delete All” options are supported. |
CNSSNG-15589 |
Slightly higher EIRP limits allowed with 2.4.1 for certain SAS vendor/model combinations as follows:
Federated Wireless SAS: · 450 SM, old limit = 45 dBm, new limit = 46 dBm, · 450 AP, old limit = 45 dBm, new limit = 46 dBm · 450i AP old limit = 46, new limit = 47 Google SAS: · 450i old limit = 46, new limit = 47 Note: While 16.2.1 radio code supports operation with these higher limits if the Grant is obtained from the cnMaestro tool, 16.2.1 code does not support the radio requesting the higher values directly. Existing operators who deployed devices with these lower limits who want to bump up their power by 1 dB should see the CBRS Consolidated Procedures Guide version 1.3 for editing EIRP on a config_synced radio. Until newer radio software is available, an existing operator who wishes to obtain a grant with 1 dB higher power will have to deregister such device long enough to request a new grant from the tool, then sync this new grant to the device. This should be done in a maintenance window prior to a CPAS cycle. |
CNSSNG-15621 |
The mailing address is used as a login to enter MSP users shouldn't be case sensitive |
CNSSNG-15724 |
Alarm CBRS_GRANT_SUSPEND is not clearing |
CNSSNG-15726 |
Invalid configuration generated when VLAN's DHCP Relay Agent is cleared. |
CNSSNG-15903 |
Mismatch in parameters in Performance Reports (Backhaul vs Enterprise Account types) |
CNSSNG-16238 |
Account field at AP Group > Network > SIP Subscriber Information does not accept special characters other than underscore (_) |
CNSSNG-16250 |
Exported ePSK entries are not human-friendly |
CNSSNG-16625 |
If the Local IP address is out of DHCP range, that IP should be allowed for R-series from AP Group > LAN setting |
Known Issues
The following issues exist:
Id |
Issue |
Details |
AURA-470 |
Failure to load success page after quick pay authentication |
CNREACH-139 |
Radio Software Update is not happening for EP based devices. |
CNSSNG-4083 |
DHCP errors after cnMaestro reboot |
When cnMaestro On-Premises is rebooted, after Data Import, sometimes DHCP and Disk Errors are encountered. Workaround: Explicitly run the dhclient command from the Command Line (accessed through the CLI) after reboot to assign the IP address. |
CNSSNG-4906 |
Captive Portal Auto Login fails with latest Android devices |
Workaround: Whitelist the URL for Google (*.google.com). |
CNSSNG-5365 |
RADIUS Proxy drops packets after retry exhausted |
After RADIUS Proxy Retries are exhausted in cnMaestro On-Premises, all subsequent RADIUS packets are dropped. Workaround: Reboot cnMaestro. |
CNSSNG-6293 |
Mesh Recovery WLAN Profile is not shown in On-Premises or Cloud. |
CNSSNG-8304 |
ePMP: “No GPS Sync” or |
ePMP devices are not sending the GPS Sync status events to cnMaestro when GPS Sync is down or there is NO GPS Sync. Also for PMP GPS SYNC events, details shows sync source instead of indicating whether the GPS SYNC source is up or Down. |
CNSSNG-9631 |
High Availability: Network cable unplug: Device count is taken from Primary and jobs/users list is taken from Secondary. |
CNSSNG-9632 |
High Availability: Network cable unplug: Devices onboarded during network disconnect need to be reapproved by user. |
CNSSNG-10145 |
Certificate exports are not part of Data Backup and Restore |
Certificates must be exported manually. |
CNSSNG-10187 |
While Migration is happening, moving or deleting a device from the Managed Account will mark all the events and alarms as undefined once migration is completed |
CNSSNG-10189 |
cnReach performance reports do not have throughput values for radios |
CNSSNG-11299 |
AP Regulatory Channel list support check needed for checking valid channels. |
CNSSNG-11389 |
Microsoft Edge Browser does not support in system OVA file upgrade. |
Workaround: Use the Google Chrome browser |
CNSSNG-11987 |
Failed - Bad Certificate' errors while downloading the generated report after a period of report generation. |
CNSSNG-12812 |
cnPilot R-series dual radio devices (r-201P, r-195W) AP Group country code/SSID configured from overrides getting applied only to 2.4 GHz radio. |
CNSSNG-12888 |
Connected Clients count in the WLAN page is not properly shown when SSID is overridden for the particular WLAN at device level. |
CNSSNG-13144 |
CBRS Management tool status field is not updated in heartbeat state. |
Workaround: Prior to syncing the configuration to the radios, any state change from the SAS does not automatically get updated on cnMaestro. A refresh on the Management tool page is necessary. |
CNSSNG-13457 |
For cnPilot-R devices, if hostname has an embedded quotation mark, the name is truncated when pushed to devices. |
CNSSNG-13598 |
EPSK keys not available in exported WLAN JSON. |
CNSSNG-14030 |
CBRS: Race condition - SM "stuck" in cnMaestro during reparenting if import and start occurs as SMs arrive in onboarding queue |
Workaround: To avoid this issue, follow the suggested SM reparenting procedures listed in the latest version of Cambium CBRS standalone procedures document. |
CNSSNG-14518 |
Device Type drop down need to be provided at Site and AP Group level for reports generation. |
CNSSNG-15313 |
Dashboard Throughput Graph and Capacity Graph for PTP devices are not updating other than Chrome browser. |
CNSSNG-15410 |
SMs connected to ePMP MP 3000 are not shown under the AP in the cnMaestro tree. |
CNSSNG-15432 |
Deleting a device in base infrastructure and claiming it immediately to another Managed Account returns Device Registration Failed message. |
CNSSNG-15656 |
Duplicate entries observed in 802.11ax Clients Report. |
CNSSNG-16161 |
Hover over message for "Registered" field incorrect in Management Tool for 2.4.1 when device builds are less than 16.2.1 |
Workaround: Devices should have 16.2.1 or higher builds for live status to be shown properly with cnMaestro 2.4.1 release |
CNSSNG-16197 |
CBSDID search will not work when device was synced from tool without obtaining grant first |
Workaround: Perform CBSDID search from domain proxy view on cloud to obtain mac address, then perform MAC address search on tool to find the device |
CNSSNG-16257 |
Exported file device type will come empty when the original device type is mismatch from the imported device type, UI will shows incorrect device type |
Workaround: Re-import with correct device type or delete the sector and import with correct device type |
CNSSNG-16258 |
If sector is not started, and device type is different, the CBRS process will not start and throw error 200[installationparam] |
CNSSNG-16260 |
If SM device type is not correct, then SM will never show config synced |
CNSSNG-16262 |
When moving from part 90 to 96, and CBRS tool has incorrect device type, even tool shows config synced, AP will not start transmission |
CNSSNG-16290 |
[EPSK] PSK's are displayed as either "Err" or “#NAME?” in excel exported because the key starts with “=” symbol |
CPY-16763 |
cnMaestro still shows device deregistered and not synced. |
FLCN-7839 |
AP keeps renewing IP address continuously, when IP address is added in cnMaestro GA whitelist entry, due to which GA redirection also fails in this scenario, as AP uplink ethernet connectivity keeps flapping. |
FLCN-7847 |
With cnMaestro GA, client GA session is not maintained after AP reboots, as AP is not sending client cache query to cnMaestro when client connects back. cnMaestro based roaming also will not work due to this issue. |
FLCN-7857 |
cnMaestro GA redirection fails with WLAN mapped to NAT'ed interface. |
Where to Get Help
There are a number of places to get help with cnMaestro.
- Cambium Community: The cnMaestro Forum provides the best place to ask questions and get up-to-date information.
- On-Premises Quick Start Guide: This guide walks you through the initial management process and allows you to get onboarded quickly. It is embedded into the cnMaestro image and can be accessed on the Home Page of the UI. It can also be downloaded in PDF format from the Cambium Support website.
- Cambium Support: The Cambium Support team is available 24x7 to answer questions and resolve issues.
