cnMaestro 3.0.0 stuck Data Migration
Good morning,
I hope someone can help us.
We have upgraded cnMaestro from 2.3.0-r28 to 3.0.0-r19 and it takes about 8 hours with the banner “Data Migration to 3.0.0 In Progress. Do not initiate System Backup and Data Report jobs or restart the system.”
Is this normal?
If I generate a backup, it does it from the previous version.
Thanks and best regards.
We have same trouble. Banner show: “%
Data Migration to 3.0.0 In Progress. Do not initiate System Backup and Data Report jobs or restart the system.” , but still 0% progress. More then two days from upgrade.
How can we fix it?
Best regards
Jaroslav Šafranek
Hi safranek_j
We finally could fix the problem, in order to upgrade cnMaestro from 2.3.0-r28 to 3.0.0-r19 we had to upgrade from 2.3.0-r28 to 2.4.0 version an then from 2.4.0 to 3.0.0-r19 We did a backup in each version in case we found a problem, but everythink went ok.
Best regards
