Introduction
This document highlights new features and significant updates in cnMaestro 3.0.4.
Important: Package Upgrade
cnMaestro On-Premises 3.0.4 is a Package release rather than a full OVA image. It must be applied on top of an existing 3.0.0 or 3.0.2/3.0.3 On-Premises installation.
Important: Web Browser
Restart your browser (or clear the browser cache with a hard reload) if you still see the older version.
Important: Update Precautions for CBRS Customers!
If you are using CBRS with cnMaestro acting as an HTTP Proxy, we strongly recommend configuring an external HTTP Proxy before updating to 3.0.4.
Anchor Account Creation
Cambium recommends all cnMaestro On-Premises users create Anchor accounts for their On-Premises installations, so they can simplify CBRS management. This will become a mandatory requirement starting in cnMaestro 3.2.0.
Organizations
Only Super Administrators can configure Organizations.
Third-Party WMS Geolocation Map Server
Support for a third-party WMS Geolocation Map Server is added to replace the default cloud-based tile mapping service. This configuration is available at the Administration > Settings page.
60 GHz cnWave Enhancements
Auto Manage Routes: Automates IPv6 Routes to DNs and CNs based on topology and PoP nodes status. Applicable only if PoP nodes and E2E Controller are in same Network/Prefix length.
Download device software image over HTTPS (supported from E2E Controller version 1.2).
Hide Sites and Add Nodes in E2E Network Tree Menu.
Debug and Remote Commands at Node and Network level (Supported from E2E Controller version 1.1).
New flow to send Node Association/Disassociation requests for links.
Summarized CPE Prefix in BGP parameters and removed offline node BGP statistics.
VLAN configuration to allow/drop untagged packets when Layer 2 Bridge is enabled.
Option to configure DHCP option 82 when Layer 2 Bridge is enabled.
Instantaneous Offline Alarm
Support instantaneous “Device Offline” alarms, instead of waiting 5 minutes before sending the alarm. Enable this with caution, because it may generate false alarms due to slow or unstable connections.
Enhancements to Active Alarms
The following updates have been made to Acknowledged Alarms:
- They are no longer included in the Active Alarm count.
- They are displayed after Unacknowledged Alarms at the same severity level.
- The font of the Active label will be regular instead of bold.
Sorting and filtering support are also added for the Acknowledge column.
Map Enhancements
The following are significant updates to Maps:
- The Map display is restructured with a collapsible sidebar that supports configuration and status.
- The icons are leaner to optimize real estate. The Tower and Site icons display device count.
- Smoother zoom experience on scroll.
Removed Reregistration Map Mode and added a new Link Quality Indicator (PMP).
Miscellaneous UI Improvements
Grid size is retained while moving across different grids within the current UI session. Also, column chooser options are retained for individual grids within the current UI session.
Supported Cambium Products
cnMaestro supports the following Cambium Networks products. The software versions are the minimum required to use cnMaestro (not the recommended versions).
Family | Model | Version |
cnPilot Home | cnPilot R200, R200P | 4.2.3-R4 |
cnPilot R201, R201P | 4.2.3-R4 | |
cnPilot R190V, R190W | 4.3.2-R4 | |
cnPilot R195P | 4.5.2 | |
cnPilot R195W | 4.7 | |
Enterprise Wi-Fi | cnPilot e400/e500 | 2.5.2-r3 |
cnPilot e410/e430w/e600 | 3.5.2-R4 | |
cnPilot e501S/e502S | 3.2.1-r6 | |
cnPilot e700 | 3.8 | |
cnPilot e425/e505 | 4.0-r17 | |
cnPilot e510 | 3.11.4-r9 | |
XV3-8 | 6.0 | |
XV2-2 | 6.1 | |
ePMP 1000 Hotspot | ePMP 1000 Hotspot | 2.5.2-r3 |
ePMP | ePMP 1000, Force 180/200 | 2.6.2 |
ePMP 2000 | 3.0.1 | |
ePMP Elevate XM/XW | 3.2 | |
ePMP Force 190 | 3.5 | |
ePMP Force 300 | 4.1 | |
ePMP PTP 550 | 4.1.1 | |
ePMP Force 130 5 GHz | 4.3.2 | |
ePMP 3000L | 4.3.2 | |
ePMP Elevate SXGLITE5, LHG5 | 4.3.2.1 | |
ePMP Force 130 2.4 GHz | 4.4 | |
ePMP Force 300-19, 19R, 13 | 4.4 | |
ePMP 3000 | 4.4.1 | |
ePMP PTP 550 E | 4.4.2 | |
ePMP MP 3000 | 4.5 | |
ePMP Force 300-13L | 4.5.2 | |
ePMP Force 300-13LC, 22L, 25L | 4.6 | |
ePMP Force 200L | 4.7.0 | |
ePMP 4000, Force 400 GPS, 400 CSM, 425 | 5.1.0 | |
PMP | PMP 450i, PMP 450, PMP 450m, PMP 430 SM | 15.0.1 |
PTP 450, and PTP 450i | 15.0.1 | |
MicroPoP Omni/Sector | 16.2.1 | |
PTP | PTP 650 | 01-47 |
PTP 670 (650 Emulation) | 01-47 | |
PTP 670, PTP 700 | 02-67 | |
cnReach | N500 | 5.2.17e |
cnVision | Hub 360r, FLEXr | 4.6 |
Client Micro, Mini, Maxr | 4.6 | |
cnRanger | Sierra 800 | 1.0.1.0-r1 |
Tyndall 101 | 1.0.1.0-r1 | |
Tyndall 201 | 2.0.0.0-r1 | |
60 GHz cnWave | V5000 | 1.0 |
V3000 | 1.0 | |
V1000 | 1.0 |
Supported Browsers
cnMaestro supports the following browsers:
Platform | Browser | Version |
MS Windows | Chrome | 49 and above |
Firefox | 45 and above | |
Internet Explorer | Deprecated | |
Microsoft Edge | 44.17763.1.0 | |
MacOS | Safari | 9 and above |
Linux | Chrome | 49 and above |
Significant Fixes
The following issues have been fixed:
Id | Details |
CNSSNG-10144 | Provide view permissions for Floor plan for operator/monitor users. |
CNSSNG-19906 | When clients roam from one AP to another AP, the client count in Dashboard and Client Table do not match. |
CNSSNG-20576 | Delete option is not visible when the browser zoom resolution is more than 50%. |
CNSSNG-20868 | On-Premises still shows old Cambium ID in the Cloud Connectivity page when the Anchor account Cambium ID is renamed. |
CNSSNG-20891 | Scheduled Job with multiple devices is marked completed if any device in the Job is deleted. |
CNSSNG-20993 | CBRS Tool sends duplicate request, which sometimes causes an error. |
CNSSNG-21022 | PMP 450 5GHz CBRS error messages. |
CNSSNG-21185 | Mobile View: Site, AP Group, ePMP, cnVision device graphs are not reflecting. |
CNSSNG-21349 | Inventory shows only Site as column name but includes Site/Tower under it; however, Grid export pulls only Site names and ignores Towers. |
CNSSNG-21356 | ‘Search’ functionality of substrings is not working in the Port column of Switch Group. |
CNSSNG-21862 | GPS Firmware is out of date triggered by the latest GPS firmware versions. |
Known Issues
The following issues exist:
Id | Issue | Details |
CNREACH-139 | Radio Software Update is not happening for EP-based devices. | |
CNSSNG-4083 | DHCP errors after cnMaestro reboot When cnMaestro On-Premises is rebooted, after Data Import, sometimes DHCP and Disk Errors are encountered. | Workaround: Explicitly run the dhclient command from the Command Line (accessed through the CLI) after reboot to assign the IP address. |
CNSSNG-5365 | RADIUS Proxy drops packets after retrying exhausted After RADIUS Proxy Retries are exhausted in cnMaestro On-Premises, all subsequent RADIUS packets are dropped. | Workaround: Reboot cnMaestro server. |
CNSSNG-9631 | High Availability: Network cable unplug: Device count is taken from Primary and jobs/users list is taken from Secondary. | |
CNSSNG-9632 | High Availability: Network cable unplug: Devices onboarded during network disconnect need to be reapproved by user. | |
CNSSNG-10145 | Certificate exports are not part of Data Backup and Restore Certificates must be exported manually. | |
CNSSNG-10187 | During Migration, moving, or deleting a device from the Managed Account will mark all events and alarms as undefined once Migration has completed. | |
CNSSNG-11299 | AP Regulatory Channel list support check needed for checking valid channels. | |
CNSSNG-11389 | Microsoft Edge Browser does not support in system OVA file upgrade. | Workaround : Use the Google Chrome browser. |
CNSSNG-11987 | Failed - Bad Certificate’ errors while downloading the generated report after a period of report generation. | |
CNSSNG-12812 | cnPilot R-series dual radio devices (r-201P, r-195W) AP Group country code/SSID configured from overrides getting applied only to 2.4 GHz radio. | |
CNSSNG-12888 | Connected Clients count in the WLAN page is not properly shown when SSID is overridden for the WLAN at Device level. | |
CNSSNG-13054 | Mismatch in Clients count for cnPilot E-series device at WLAN and AP Group configuration level. | |
CNSSNG-13144 | CBRS Management tool status field is not updated in heartbeat state. | Workaround: Prior to syncing the configuration to the radios, any state change from the SAS does not automatically get updated on cnMaestro. A refresh on the Management tool page is necessary. |
CNSSNG-14030 | CBRS race condition: SM “stuck” in cnMaestro during reparenting if import and start occurs as SMs arrive in onboarding queue | Workaround: To avoid this issue, follow the suggested SM reparenting procedures listed in the latest version of Cambium CBRS standalone procedures document. |
CNSSNG-14518 | Device Type selection needs to be provided at Site and AP Group for Report generation. | |
CNSSNG-15432 | Deleting a device in Base Infrastructure and claiming it immediately to another Managed Account returns Device Registration Failed message. | |
CNSSNG-15595 | cnMatrix Hostname fall backs to old Hostname if the template is pushed for the first time (if a Switch Group already exists). | |
CNSSNG-15656 | Duplicate entries observed in 802.11ax Clients Report. | |
CNSSNG-15838 | Issues related to Monetization Subscription Events. | |
CNSSNG-16019 | Subscriptions are not listed in the correct order. | |
CNSSNG-16197 | CBSDID search will not work when device was synced from tool without obtaining grant first. | Workaround: Perform CBSDID search from domain proxy view on Cloud to obtain MAC address, then perform MAC address search on tool to find the device. |
CNSSNG-17011 | After the migration completed for PPPoE with server update, devices still show in sync. | Workaround: User must manually apply the AP Group again on devices with minor changes to the AP Group. |
CNSSNG-18710 | Tier issues related to 450i, 450i AP, and 450i SM. | |
CNSSNG-18913 | On resizing, the graph/widgets are not properly rendering. | |
CNSSNG-18923 | After migration Reports Job page is empty due to cached data. | Workaround: Clear Cache and Cookies after migration. |
CNSSNG-18927 | Configuration push from Onboarding page is getting device timeout error in ePMP 1000 Hotspot device. | |
CNSSNG-18936 | Graphs plotting is getting empty if the page is zoomed out/in. | |
CNSSNG-19264 | Unmanaged expired device approve button is not disabled. | |
CNSSNG-19273 | Expired Wi-Fi devices are not handled for AP Group dashboards and tree level. | |
CNSSNG-19274 | Expired devices count should not be added to connection health graph. | |
CNSSNG-19275 | Issues related to Offline alarm of expired devices. | |
CNSSNG-20491 | Cloud-Connect action data missing for Cloud-Sync module in Audit logs. | |
CNSSNG-20508 | Last Super Administrator deletion should be shown proper error message. | |
CNSSNG-20605 | User-Defined Overrides (Advanced) should be handled from Switch Groups > Switches > Actions > Configuration tab. | |
CNSSNG-20745 | AP Count is -1 in Anchor when deregistering the device from Anchor. | |
CNSSNG-20820 | After server upgrade, device throws error [Invalid CBSD ID and Grant ID], even the Domain Proxy shows the device is registered. | |
CNSSNG-20868 | On-Premises still shows old Cambium ID in the Cloud Connectivity page when the Anchor account Cambium ID is renamed. | |
CNSSNG-20993 | CBRS tool sends duplicate request, which sometimes causes an error. | |
CNSSNG-21264 | Auto refresh is not working when Site/Tower/Device details are updated in network level map. | |
CNSSNG-21268 | cnMatrix devices are not reflecting in maps. | |
CNSSNG-21271 | Map: SM status is missing in AP details. | |
CNSSNG-21345 | RF Statistics related information should not be available in reports for XV type device. | |
CNSSNG-21396 | Issues related to cnMatrix onboarding overrides. | |
CNSSNG-21425 | Left side menu is not properly shown in Firefox browser. | |
CNSSNG-21540 | Found 'Failed to start SNMP Adapter for cnMaestro’ error. | |
CNSSNG-21590 | AP not syncing Error: Configuration failed: system_name: Only alphabets, digits, hyphens and underscores are allowed. | Workaround: User must manually apply the AP Group again on devices with minor changes to the AP Group. |
CNSSNG-21703 | SM icon is missing in Network-level Maps. | |
CNSSNG-21909 | Link availability graph shows down even though links are up when cnMaestro is rebooted. | |
CNSSNG-21911 | 60 GHz cnWave Dashboard Map, when there is more than one node per Site, node details are not available although count is shown. |
Where to Get Help
There are several places to get help with cnMaestro:
Cambium Community : The cnMaestro Forum provides the best place to ask questions and get up-to-date information.
On-Premises Quick Start Guide : This guide walks you through the initial management process and allows you to get onboarded quickly. It is embedded into the cnMaestro image and can be accessed on the Home Page of the UI. It can also be downloaded in PDF format from the Cambium Support website.
Cambium Support : The Cambium Support team is available 24x7 to answer questions and resolve issues.
