Looking for the OID's to disable cnMaestro on the PMP450 AP and SM's running 15.0.1
Hello
Here is the OID to enable/Disable cnMaestro: .1.3.6.1.4.1.161.19.3.3.2.257.0
Set above OID to 0 to disable cnMaestro and 1 to enable it. This OID works on AP and SM both.
Dhaval
Perfect. Is there an OID for "Reboot If Required"?
Yes.
OID to reboot: .1.3.6.1.4.1.161.19.3.3.3.2.0 - set this OID to 1 and radio will reboot
rebootIfRequired OID: .1.3.6.1.4.1.161.19.3.3.3.4.0 - set this OID to 1 and radio will reboot if reboot is required. This OID will return 0 if reboot is not required and 1 if reboot is required.
Dhaval
