Introduction
cnMaestro On-Premises is a standalone version of the cnMaestro Cloud application that can be installed in a customer's data center. This post highlights updates in the 1.6.0-r22 patch release.
Cambium strongly encourages cnMaestro On-Premises customers to apply this package to their existing 1.6.0 installation before February 1, so map visualizations can continue to be used uninterrupted.
Package Installation |
cnMaestro 1.6.0-r22 is provided as Package release that must be applied on top of an existing 1.6.0 On-Premises installation. Please follow the steps detailed on page 129 in the cnMaestro On-Premises 1.6.0 Quick Start Guide (“Updating cnMaestro Software”) to perform a package update on an existing OVA. |
Significant Fixed Issues
Updated Map Provider
This patch replaces the tiles provider, Mapzen, which is shutting down its service at the end of January. These fixes have already been applied in Cloud.
Where to Get Help
There are a number of places to get help with cnMaestro.
- Cambium Community: The cnMaestro Forum provides the best place to ask questions and get up-to-date information.
- On-Premises Quick Start Guide: This guide walks you through the initial management process and allows you to get onboarded quickly. It is embedded into the cnMaestro image and can be accessed on the Home Page of the UI. It can also be downloaded in PDF format from the Cambium Support website.
- Cambium Support: The Cambium Support team is available 24x7 to answer questions and resolve issues.
