cnMaestro On-premises massive fw upgrade
Hi, i've instlled cmMaestro On-premises and i've addess some epmp1000 gps synk sectors.
I've noticed that goung in subscriber modules nothing appears.
I've read that actually it's only for wifi environments.
Will it be available ifor the epmp1000 synk sectors n the next releases?
Also,will you add the function for a massive firmware upgrade for sectors and subs also?
Regards,
vrega
Hi Vrega,
epmp gps Sectors , Non-GPS and integrated radio can be upgraded using CnMastero.
We will check and update you regarding the Upgrading of several SM on differetn sectors.
Regards,
Abhilash Menon
Vrega,
As metnioned in the previous post, yes, cnMaestro can be used to manage ePMP devices and that includes performing bulk software upgrade of devices.
Can you clarify the problem you are experiencing?  Have you been able to successfully onboard an ePMP AP and SM?  If so, then they should appear in the device tree when you click on the MONITOR - DASHBOARD menu item.
Assuming you see the AP and SM in the device tree, you should be able to click on the device in the tree and see information about the device on the dashboard (to the right).
To perform a bulk software upgrade, use the main menue to select OPERATE --> SOFTWARE UPDATE.  In the tree, click on the on a parent folder (such as System or Network folders).  Using the pull-down menu, select the "Device Type" to be "ePMP (Sectors)".    Select the software image that you would like to apply to the devices.  In the table below, click on the checkboxes to select the devices that you would like to upgrade and then at the bottom of the page click on "Add Software Job".  In the next tab, "Active Jobs", click on the "Start Job" button.
Hi Emilio,
i've added only the epmp100 AP in the system.
My question is:
is there a way to update all the su connected to the AP without configuring one by one the SU with the cnmaestro url?
vrega
You can leverage DHCP Options 43/15 to configure cnMaestro On-Premises URL on SM devices as long as they are getting IP address from DHCP Server configured/managed by you.
Please  refer to section - DHCP Options (Linux) in User Guide to get detailed steps about the same.
Ajay
all cpe in my network have pppoe enabled and obtain the ip address dynamically.
Is there a solution?
vrega
I am assuming that in this case you don't have control over DHCP Server, which is providing IP address to all the CPEs. If this is true, then you cannot really leverage DHCP Options 43/15, so you will have to set cnMaestro On-Premises URL on each SM device.
Ajay
