It would be great to be able to use LAN2 on PMP450 for onboarding in cnMaestro on premises.
I discovered, LAN2 addresses are RF addresses assigned by AP based on their LUID. When this subnet is properly routed via AP’s IP address, you can use web management or SNMP using those LAN2 IP addresses.
Network schema attached.
The reason for this request is, that we are using “addressless” SM configuration - SM have default local IP only. We are accessing them via AP’s IP and their MAC (eg. http://172.16.10.11:1080/main.cgi?mac_esn=0a003ea18372). I consider this as great PMP450 advantage against other products. Addressing each SM (manually or DHCP) seems to me as step aside.
