Buonasera,
ho installato cnMaestro On-Promises ed ho problemi per associare i dispositivi.
questo è il log della CPE:
Sep 1 00:41:09 ePMP_Ripoli2_Bis DEVICE-AGENT[5567]: Non-cambium/cloud cnMaestro URL [https://XX.XXX.X.X], disabling Server Cert check
Sep 1 00:41:09 ePMP_Ripoli2_Bis DEVICE-AGENT[5567]: Non-cambium/cloud cnMaestro URL [https://XX.XXX.X.X/device], disabling Server Cert check
Sep 1 00:42:13 ePMP_Ripoli2_Bis DEVICE-AGENT[5567]: No REGISTER response received, closing websocket
Sep 1 00:42:13 ePMP_Ripoli2_Bis DEVICE-AGENT[5567]: callback_websocket: LWS_CALLBACK_CLOSED Qualcuno ha la più pallida idea di come posso risolvere questa cosa?
Grazie
jrosello
(jrosello)
August 4, 2016, 11:01pm
#2
i have a problems to association too, in phone calls says no have problem in cnMaestro but i think it no work fine, please REPAIR IT soon i loss a lot of time, and it no work
Can you please send your cambiumID and device MAC via private message.
Also please attach device techsupport by login from device UI
Good evening ,
we installed cnMaestro On -Premises on our private server . I do not know if I have to send attached to email Technical Support Dump , because I can not download it from the browser
If you are not able to access the browser, then you can always use CLI command.
just go to cnmaestro CLI as root user (sudo su )
Then type below command
cnmaestro-techdump
This should download the techdump in the /tmp directory and you can copy it and send the link via private message
I sent you the file by email.
