As we are aware, cnMaestro Cloud will not update the firmware on the R-200 routers without failing. From what I recently read in the forum, that is a known problem that is supposed to be corrected in the next major release of cnMaestro.
On to other things....
cnMaestro OnPremises will also NOT update the firmware on R-200 routers without failing. When attempting to go from 4.2.3- R4 to 4.3.2-R4, it comes back failed.
The Upgrade Status column gives an error message that says "Version applied was 4.3.2-R4 and device came with 4.2.3-R4"
Good deduction on cnMaestro's part. We knew that before we started.
Is this going to be fixed in the next release of cnMaestro?
