I have some problems in cnmaestro to remove some devices and also to approve new devices, follow print with problems.
- add onboard.png (20.9 KB)
- remove from inventory.png (3.78 KB)
Hi Alex,
I can see that couple of devices are Queued which means Device is not communicating with cnMaestro server
OR other devices are being updated first, Could you please check the same.
Also, may I know how many devices have you onboarded so far?
Hi, I added a little more than 50 devices, but can not be communicating with cnmaestro if the device was awaiting approval, after approving the device has gone to "waiting for device". I tried to remove the device and add again but cnmaestro shows me another error and I can not remove. The following print a device that displaying Feedback "waiting for device"
