When I try to add the 4.6r16 firmware for the R190s, it kicks back a unrecognized file error. I have that firmware uploaded for the 201s and the 195s with no issue. I have even tried redownloading the firmware to see if it was just a issue with the file that I had downloaded. I would appreicate any input.
Hi
Greetings!!
Please check the file name of the firmware you are trying to upload. Make sure it is the same as the highlighted firmware(https://support.cambiumnetworks.com/files/r-series/).
May I know the firmware version currently running on the R190 device.
Best Regards,
Gupta Bobby
