On Performance Graphs > Retransmission, the vertical axis is labeled simply "Retransmission". What are the actual units? Is this a percentage?
Please re-label the axis to represent the answer.
Thank you, Chris
Thank you, Chris
Hi Chris,
The retransmission units are % and we will try to change the vertical axis label to represnt the same
KR.
