cnMaestro - Sort by GPS Settings etc
The ability to select all AP's running certain GPS Sync settings via adding in better search filters.
I would recommend adding a selection box with all the settings relaiting to GPS Sync. In fact you could add in a whole entire new search page that allows Firmware update and Template updates.
For exapmle be able to find all AP's running 75/25 with 5ms
The reason is I may want to change all these AP's to 75/25 2.5ms but leave all the other AP's on there 50/50 setting etc.
Atm it is a nighmare to do this.
