Hi
I has picked up an issue where the provisioning worked fine, and the device overrides worked as i would expect with the older 4.3.4-R8 firmware.
After the upgrade although the SSID is in place and users are able to Autenticate from what I can tell, they do not get an IP address from DHCP, if i log into the router and manually apply the password that is in the provisioning / device over-ride the users then reconnect and get an IP address.
as overrides I am using the following
WPAPSK1=${WPAPSK1=password} password would be entered in the field under device configuration (wifipass123 etc)
SSID1=${SSID1=Clientt-WLAN} SSID would be entered in the field under device configuration (MyWiFi etc)
I have run diff's on the working and non working configs and I see no difference.
Any assistance would be welcome. please let me know what information you need.
