Hi!
We have experienced problems with cnPilot R200P after updating to SW 4.5-R7
Some routers change continuously to "bridge mode".
Is this a known problem ...?
Hi
We have not encountered this issue. Can you provideĀ
some more details/ screenshots.
From which build are you upgrade to 4.5-R7.
What was your WAN configuration before upgrade.
ashutosh
The routers were updated from SW 4.4.2-R2
Before updating, they were all set in routing mode.
After updating, they became red in cnMaestro, but distributed official IP addresses to devices connected to the LAN.
It is also not possible to reset the routers.
Upon checking I discovered that they are now in bridge mode.
